Work out nuts...info needed
the way you would know if ur over training is if YOU think your over training
also do a little bit of cardio to keep sweating off the fat for example run 1 mile every other day and try to keep it under 8 minutes.
get atleast 8 hours of sleep every night.
take naps if u need to
heres a nice schedule for you that I use
Mon - Chest/Stomach/ 1 mile
Tues - Back/Traps
Wed - Legs/Stomach/1 mile
Thurs - Shoulders/ Triceps
Fri- Biceps/Forearms/ 1 mile
Sat - Rest
Sun - Rest
Do this for 10-12 weeks to test it out and tell me if you like it bcuz i guarantee you that you will see a large increase in strength and size and if u like your results keep using the same routine just increase ur weights
My advice is don't be in a rush, because nothing happens over night. Good luck with it.
anyways, there's alot of different input here and far more than I thought I was going to get, I know I can build the weight I want because I used to be 175-180 when I was about 5-7 yrs younger, just kinda forgot how I did it....going to start getting into the run of things in about a week when i get the spare time while my G/F is back at school in S.C.....
PS... as recommended before, you can cut out cardio. If you want to still do cardio, then walk on the treadmill at an incline which will burn more fat than calories. You need to be taking in more calories than you are burning or else you will be burning muscle. As far as not eating carbs at night, that cant be more wrong when trying to gain weight. Cutting out carbs at night is for people wanting to loose weight.
