is this normal
Old Apr 22, 2009 | 07:09 PM
chevy0128's Avatar
Default is this normal
if i am at wide open throttle and get up to redline or close to it and then press the clutch in the rpm go down but it will hover at a high rpm like 1800 or 2000 and then go back down to rpm like normal
Old Apr 22, 2009 | 08:38 PM
Adam98Z's Avatar
I assume you are letting off the gas when you push the clutch in?
Old Apr 22, 2009 | 10:34 PM
02txceta's Avatar
Sounds like a TPS or IAC issue to me.
Old Apr 22, 2009 | 11:16 PM
chevy0128's Avatar
yes i am letting off the gas what is TPS and IAC
Old Apr 23, 2009 | 06:42 AM
98FreakZ's Avatar
TPS- Throttle Position Sensor
IAC- Idle Air Control
Old Apr 23, 2009 | 10:05 AM
Adam98Z's Avatar
Agreed. Check those out first.
Old Apr 27, 2009 | 11:08 AM
chevy42083's Avatar
I've driven a few cars that did that. I always assumed it was to aid in smooth shifts. Kinda like rev-matching for the next gear.
Old Apr 27, 2009 | 12:18 PM
chevy0128's Avatar
thats what my first thought was to so thats why assumed it may be normal
Old Apr 27, 2009 | 01:08 PM
78novacaine's Avatar
mine does that sometimes, will drop to about 1300-1500 rpm or so, then once i stop completely it will drop back down to 700-800
Old Apr 27, 2009 | 02:24 PM
twitchtwice's Avatar
i think it may depend on how fast you are going to be honest? my little carolla does that when im driving a little fast, like 60+
Old Apr 27, 2009 | 04:11 PM
yeah, mine pretty much only does it if im cruising in 6th and then coast to a stop
Old Apr 27, 2009 | 04:29 PM
goober35's Avatar
Mine TA did it and so does my dodge diesel.
Old Apr 27, 2009 | 09:52 PM
1bdBULLITT's Avatar
Mine does it but it was also tuned by HPE.....
Old Apr 28, 2009 | 12:03 AM
CySevans's Avatar
Do you have any aftermarket modifications, like a cam that required drilling a larger hole in the throttle body? Engine will rev as long as it's getting air. Let it rev. Might want to check into the tuning and stick to premium fuels.
http://www.misterfixit.com/deton.htm
