help me make a maintenance list
change tranny fluid
change rear diff fluid
flush brake fluid
flush power steering fluid
flush coolant
seafoam the car
sparkplugs and wires
belts
is there anything else fluid wise i can/should change, should i grease or lube and joints or bearings? i have some dimpled rotors i have to install in all 4 wheels along with brake pads. i know alot of this is not required but id rather go ahead and do it for peace of mind. thanks for any input
i did the fuel filter around 30k, had the clutch master cylinder and clutch fluid replaced at 40k due to sticky clutch
air filter, wiper blades. Check the water pump weep hole. While you're doing the coolant, you can change the thermostat out.
Definately grease all the balljoints and bearings you can.
