Quick question
Old Jun 2, 2009 | 05:43 PM
RobZ's Avatar
Default Quick question
Does a b+ pinout on the pcm have to be 12 volts exact or 11.5 or 11.7 ish?Using a voltmeter to read but not sure.
Old Jun 2, 2009 | 08:56 PM
RobZ's Avatar
Anyone?I had the P0342 code Camshaft Position Sensor Circuit Low Input.I found two wires that were nicked so I cut the bad parts off.No more Codes,but the car still backfires.Do you think the volts that I registered on the voltmeter are to low and need to replace the computer.
Old Jun 2, 2009 | 10:38 PM
red90cobra's Avatar
I would check the volts coming from the battery first. and see how they compare.
