got a weird MAF/idle problem... need some help
I bought the car with a check engine light. Pulled the code, and it was "MAF or VAF circuit low input". Checked the fuses, saw the ENG SENSOR (20amp fuse) was blown. Replaced the fuse, reset the code, ran the car a bit... code popped back on, and the fuse blew.
Replaced the fuse again, with a 30amp fuse, reset the code, ran the car a bit... code popped back on, and the fuse blew again.
I've checked the voltage going to the sensor with a test light and all the wiring is good, nothing seems shorted in/around the harness.
Disconnected the MAF, replaced the fuse... car ran fine w/o the MAF, code popped back on, but no blown fuse!
Picked up a brand new 6.0 Delphi MAF, swapped them out, and here's where it gets weird...
Got a NEW code now: Idle control system-RPM low
car runs fine on the road, but idles really really rough and really really rich, however, no blown fuse, and no MAF code with the new Delphi MAF installed.
I'm beyond confused on where to look now. Maybe the car was tuned with a bad MAF, and now has a properly working MAF and screwed with the tune.
Any ideas/suggestions are great appreciated, thanks.
