Not an LSx dyno but...
Old Oct 26, 2009 | 01:36 PM
Mr Powell's Avatar
Default Not an LSx dyno but...
I am damn proud of it...
First off this is just the first round of numbers on a file (tune) that has less timing then a pump gas tune has. You will notice this because the mid-range is down on power, but when the tuning is complete it will be back to normal.
The car is my 2002 Porsche 996 Turbo w/
Boost Logic 900+ Kit (Precision BT5857's w/ TiAL 44mm Wastegates)
Boost Logic 6" Intercoolers
Boost Logic Custom Intake Pipes/Y-pipe/TiAL 50MM BOV's
Boost Logic Custom Fuel System (1000cc Injectors, 2x Pumps, Surge Tank, Lines, etc..)
Tilton Triple Carbon Clutch
EPL (European Performance Lab) Tune
Aquamist HFS-6 Water/Meth Kit (Not installed at the moment)
Switzer Exhaust (But these dynos were through 3" Straight Pipe)
Stock Motor
This run was done on MS109 @ 1.5bar (~22psi). The weather was in the mid 70's in Austin. This was also done on Boost Logic's DynoJet which is suppose to be very stingy on power...
STD Correction (That a lot of people seem to use to inflate numbers...)
SAE Correction (The real correction factor)
We will be dynoing over the next week to tune for a little bit higher boost (1.7bar or ~25psi), more timing in the midrange and a tiny bit more up top. I HOPE we break the 850rwhp area. This would make the car the highest HP stock motor 996TT in the world. I will hopefully make closer to 700rwhp on pump gas + Meth so it shouldn't be a slouch on pump either! When the motor gets built I don't think I'll have a problem touching the 1000rwhp area!
I know dyno numbers don't mean a thing so it will be at the track ASAP for 60-130 and 1/4 mile numbers. I hope to dip into the 4s in the 60-130 and run in the easy mid 140 area in the 1/4. I cannot launch the car due to stock axles so I won't get a good time. Hopefully I'll have enough traction for good passes on both. I will be going full RWD soon, so I do not risk my front drivetrain anymore.
I'll be getting some nice pictures of everything when I get the car back from Austin. I finally lowered the car with some coil overs so no more monster trucking for me!
To the haters... Just keep the comments to yourself...
Old Oct 26, 2009 | 01:52 PM
posz28's Avatar
very nice
Old Oct 26, 2009 | 01:53 PM
-Ross-'s Avatar
Awesome numbers, Chris. Congrats.
Old Oct 26, 2009 | 02:09 PM
Kamikazekyle05's Avatar
Thats awesome
Old Oct 26, 2009 | 02:14 PM
Sarge_13's Avatar
Badass Porsche. How do you plan on going RWD?
Old Oct 26, 2009 | 02:18 PM
pennys58's Avatar
Nice numbers Chris! It will be interesting to see what numbers the new tune produces!
John
Old Oct 26, 2009 | 02:19 PM
FlashWS6's Avatar
Destroyer of Exotics
nice!!!
Old Oct 26, 2009 | 02:23 PM
SSilverSSurfer's Avatar
saw it on the 6speeds forum bad *** build congrats
Old Oct 26, 2009 | 02:27 PM
Mr Powell's Avatar
On the Porsche it is really easy, and doesn't take too much time. All that needs to be done is take the Front Diff/axles out and the driveshaft from the rear to the front. Then get an alignment and call it a day.
I should be receiving a few new files in the next day or two. So we'll have some even better numbers soon. Only other numbers which I may have soon are dynos with the same boost in the 50* weather in Austin and a dyno at 25-26psi in the same weather on the same base tune.
Old Oct 26, 2009 | 02:39 PM
XplicitPerformance's Avatar
that thing should move out pretty damn good! thats damn good power. how much that thing weigh anyways?
Old Oct 26, 2009 | 02:41 PM
Mr Powell's Avatar
Sad thing is that the car is real pig. With me in it (before GT3 Replica Seats and RWD removal) the car weighed 3650lbs with a 1/4 tank of gas. It should hopefully be in the ~3500lb area with me in it though when I get it back and the AWD stuff out.
Old Oct 26, 2009 | 02:51 PM
nassty00's Avatar
nice numbers. congrats man
Old Oct 26, 2009 | 03:01 PM
Mike TexaSS's Avatar
8 Sec Tuner
Herbie's gonna roll out!
Old Oct 26, 2009 | 03:07 PM
F1C YA's Avatar
Im gunna keep my comments to myself.........jk, lol... The car is bad *** Chris!!!! Good job!
Old Oct 26, 2009 | 03:21 PM
G-Z06's Avatar
sick!!
Is there something you can do to beef up the front to keep it AWD?
I know some of the Gallardo's that are pushing 1000+ are keeping AWD
Be safe in that beast
Old Oct 26, 2009 | 03:36 PM
niceguyyy01's Avatar
Very cool Chris. Congrats on the numbers.
Old Oct 26, 2009 | 04:12 PM
Robert@G-Force's Avatar
Still gonna run a 11.00 lol
Old Oct 26, 2009 | 04:33 PM
NVR4GET's Avatar
at 145mph!
Old Oct 26, 2009 | 07:58 PM
o2ws8's Avatar
Nice!!
Old Oct 26, 2009 | 08:02 PM
That_guy's Avatar
thought that porsche was awd. hell still a lot of power though.
