Blown header gasket??
Old Nov 7, 2009 | 10:24 PM
Randy_S's Avatar
Default Blown header gasket??
Is that common or at least viable? I have an odd sound clacking under the hood and i don't think it is a lifter. I noticed a rich smell under the hood and felt heat coming from the driver's side pushing up in one area.
Old Nov 7, 2009 | 11:33 PM
98Roller's Avatar
i used the paper header gasket supplied by pacesetter. It blew out. If you unbolt the header and pull out the gasket you will see black where it is leaking.
Old Nov 8, 2009 | 02:01 AM
ex-SS-ve's Avatar
if your using the factory multilayer gasket im pretty sure that a bolt has backed out. just retighten all the bolts and youll be good to go.
Old Nov 8, 2009 | 11:37 AM
Randy_S's Avatar
It is the gasket that came with the Kooks I believe. i am going to call G-Force tomorrow to pick their heads.
Old Nov 8, 2009 | 11:49 AM
SiL3NtXWS6's Avatar
Yeah, if it's a paper, chances are it blew. It's common, happened to me when I used paper gaskets.
Next time, just re-use your stock metal ones.
Old Nov 8, 2009 | 01:57 PM
CarsandWomen's Avatar
i always run the copper ones, there reusable too. and yes a loud clacking is the sound blown header gaskets will make, check the bolts too
