View Poll Results: Weiland or LS6
Weiland intake
2
33.33%
LS6 intake
4
66.67%
Voters: 6. You may not vote on this poll
Weiland intake vs LS6
Old Nov 12, 2009 | 05:40 AM
98Z2885's Avatar
Default Weiland intake vs LS6
I looked them up and the seem to be real close in power. Is this correct, or is it not? Im looking into buying a Weiland intake. Lets hear your thoughts on the two. I have just a stock LS1 intake now. Im going to buy LS6 heads, and a MS3 cam to go with the combo.
Old Nov 12, 2009 | 08:02 AM
v8's Avatar
v8
17,16,15,14,13,12,11 Drvr
if your going to spray the car get the weiand, if staying N/A get the LS6 style.
Old Nov 12, 2009 | 08:10 AM
adam02gt's Avatar
Unless you get a crackhead deal on the weiand just buy a ls6 or if you can swing it the fast 78 intake works good.
Old Nov 12, 2009 | 09:22 AM
Inspector12's Avatar
TT-TECH Veteran
They are very close in design if not exact. The down fall of the Weiland is heat soak and they don't have O-ring on the sealing surface so they leak a lot and are very hard to get to seal! I have seen people take them and have the O-ring grove installed with good results on the leaking issue, but IMO its a lot of $$ for that intake and an LS6 is just as good if not better in a lot of respects and handles N02 just fine. GL!
Jeff
