Wth??
Old Dec 9, 2009 | 11:28 AM
k_dub09's Avatar
Thumbs down Wth??
So I went to get into my car to head to work this morning, popped the door open and sat down. I put the key in, pushed the clutch in, turned the key and NOTHING happened. All my electronics are on, and the headlights dim when I turn the key.. No clicking noise or anything other than the lights dim. Could this be a starter issue? Just cold weather? She started up just fine yesterday! Any ideas or help is greatly appreciated, thanks in advance!
- Kyle
Old Dec 9, 2009 | 11:34 AM
98Z2885's Avatar
Sounds like a battery. Mine did this last week. My battery was fine a week earlier, and I came out to get something out of it, and it was dead. No door locks or anything.
Old Dec 9, 2009 | 11:39 AM
GR8RYD's Avatar
I would start with the battery. Mine did the same thing. Started just fine, drove home and parked out front. Went out the same day and NOTHING! The only warning I had (which I did not heed) was the speedometer and tachometer bouncing hard when I would go to start it, one out of 10 times in the prior 6 months or so.
Old Dec 9, 2009 | 11:46 AM
Super-Bat's Avatar
Start with battery, then check alternator, then starter.
Sucks. I think this "sudden" cold weather has alot of our cars acting funny.
My car was acting strange yesterday. After it got to operating temp, everything was fine.
speedracer2536's Avatar
eithier the batt. or it could be your vats system.
Old Dec 9, 2009 | 01:46 PM
k_dub09's Avatar
So y'all think it's the battery even though everything turns on?
Old Dec 9, 2009 | 01:51 PM
Take 2's Avatar
It took you longer to post this up then it would have took to try and jump it off and see....
Could be the Battery just jump it or charge it to see..
1badassz's Avatar
Could be the switch at the top of the clutch pedal is going out. Mine does it occassionally. Press the clutch all the way to the floor and slowly let up while trying to start it. That usually gets mine going.
Old Dec 9, 2009 | 01:59 PM
k_dub09's Avatar
I'll try the clutch thing when I get get home today and if that doesn't work I'll try and jump it. Is that clutch switch easily accesible?
Old Dec 9, 2009 | 02:16 PM
Juicy J's Avatar
Is there a security light that stays lit on the dash? If so, just wait 5 minutes and try it again.
If the security light comes on, and stays lit, your vats system has gone bad.
Old Dec 9, 2009 | 02:20 PM
redz_02's Avatar
You can always pull the starter and have it tested.
Old Dec 9, 2009 | 02:26 PM
Domsz06's Avatar
My corvette would do the same thing, and I noticed it was the clutch pedal/switch. If it was not depressed the ENTIRE way it wouldn't start. there were times I thought I was pressed all the way down, and it wouldn't start, so I would just let go, and do it again and it started everytime. Same thing happens now that I have an automatic in her. If the gear selector isn't pushed ALL THE WAY forward it thinks int's in gear and won't start.
Might try it, it's worth a shot before you go start pulling batteries and starters.
Old Dec 9, 2009 | 02:43 PM
k_dub09's Avatar
Ok, thanks for the help guys!
Old Dec 9, 2009 | 02:48 PM
jaysan's Avatar
Post your findings man
Old Dec 9, 2009 | 04:41 PM
devious's Avatar
Sounds like VATS
Old Dec 9, 2009 | 05:36 PM
gun4hire's Avatar
Mine did the same thing with a LOOSE battery conn. Odd but it was letting enough power through for the rest of the car, but not enough for the starter. I tightened the power cables and the car fired right up.
She must have known I was thinking about selling her at the time... lol
Old Dec 9, 2009 | 06:52 PM
k_dub09's Avatar
Good news!! It was the clutch pedal switch.. Took off the connector, and plugged it back in and pressed the button several times and she started like a champ! Bought a new switch at oreilleys for $7.. Not bad
Old Dec 9, 2009 | 06:56 PM
99 DUKE'Z 28's Avatar
haha congrats. my guess would have been VATS if ur security light was flashing
Old Dec 10, 2009 | 09:00 AM
Juicy J's Avatar
Got to love the easy fixes.
Old Dec 10, 2009 | 09:12 AM
Domsz06's Avatar
good deal, glad she is working again!
