Lq4 Th350...
Old Feb 23, 2010 | 12:14 PM
MrCheap's Avatar
Default Lq4 Th350...
Not sure exactly which flexplate, bolts, and spacer I need to put a th350 behind my lq4. I've searched and searched and everybody has a different opinion. Any of you guys actually done it? I have the stock curved flexplate, gen1 converter, and the gm spacer. Is this the correct setup? Thanks
Old Feb 23, 2010 | 05:14 PM
NemeSS's Avatar
just stick with actual 6.0 lq4 plate and spacer with matching or arp bolts. can use 10 sbc tq coneverter or custom. not reccomend hi rpm with stock plate and bolts.
Old Feb 23, 2010 | 05:18 PM
ZONES89RS's Avatar
In-Zane Moderator
Yep, i have a LQ4 flex plate i am not using if you need it. Has the spacer built onto it.(T56 FTMFW)
Old Feb 23, 2010 | 06:29 PM
MrCheap's Avatar
Ok, thanks. I think I've got ls1 flexplate bolts, not the longer 6.0 bolts, that's what was throwing me off. The spacer will go between the TQ and the flexplate then, correct? Crank-flexplate-spacer-TQ...
I think mine will work, thanks though. You have the stock 6.0 bolts? T56 was the plan, just got a really good deal on my trans lol
Old Feb 23, 2010 | 07:38 PM
ZONES89RS's Avatar
In-Zane Moderator
Hmmm, have to look around and see if i have them and dont need them.
Old Nov 6, 2010 | 08:07 PM
kvn1011's Avatar
ok here is a th350 via google
and my LQ4
from the looks of this would i just need to elongate the holes circled in red on the flexplate of the Lq4?? and will i need longer bolts??
thanks kev
Old Nov 6, 2010 | 09:13 PM
built408's Avatar
^^^ That doesn't appear to be a LQ4, an LQ4 would be backed with a 4L80e which would have a 6 mounting points.
Old Nov 6, 2010 | 10:22 PM
1c62nv's Avatar
You are correct, In fact if anyone has an lq4 FP with 6 holes I sure could use one.
Old Nov 7, 2010 | 11:48 AM
1-87 chevy's Avatar
all you need is a stock fly wheel from a 5.3 or 4.8 and the spacer off an 6.0 . the spacer will be mounted between the fly wheel and the converter. the spacer is used this way to help with the shorter pilot on the 350 /700 /400
Old Nov 7, 2010 | 09:14 PM
ZONES89RS's Avatar
In-Zane Moderator
Mine had the spacer built onto the flywheel.
Old Nov 8, 2010 | 12:52 AM
txh0tb0i972's Avatar
it sure did
Old Nov 8, 2010 | 10:20 AM
ZONES89RS's Avatar
In-Zane Moderator
Couldnt remember who i sold it to, LOL.
Old Nov 10, 2010 | 09:51 AM
kvn1011's Avatar
ok, i have checked the block and it is stamped 6.0<< and checked vin it shows as being a 2005 4 wheel drive denali
Originally Posted by 1-87 chevy all you need is a stock fly wheel from a 5.3 or 4.8 and the spacer off an 6.0 . the spacer will be mounted between the fly wheel and the converter. the spacer is used this way to help with the shorter pilot on the 350 /700 /400
thanks 1-87 chevy
