6.0 question...
Old Mar 2, 2010 | 06:59 PM
layz's Avatar
Default 6.0 question...
i got a 6.0 block and was wondering if any of my ls1 out of my 2000 camaro will fit on the 6.0 block...and if so what would i need to get..i am wanting to get it running for now and do a cam swap later...will my tranny 4l60e fit on the 6.0.....basically what will i need to get it running...
Old Mar 2, 2010 | 07:39 PM
ZONES89RS's Avatar
In-Zane Moderator
If you have just a bare block, the crank and rods will swap out im sure, as well as the heads and everything else, just need to drill and tap 1 hole for the accessories, but you will need pistons...
If you have a shot block or long block you are in better shape labor wise.
Old Mar 3, 2010 | 02:04 PM
redz_02's Avatar
I know the crank fits for sure.
Old Mar 3, 2010 | 02:49 PM
$750 L98's Avatar
Pistons won't. 5.7 is 3.9" and the 6.0 is 4.025 or some such if I remember right.
Old Mar 3, 2010 | 03:45 PM
ragu1585's Avatar
tranny should be fine too
Old Mar 3, 2010 | 04:19 PM
Elite_Hot_Rod's Avatar
6.0 = 4.000" bore.
Old Mar 3, 2010 | 04:20 PM
I think the LS1 rods would be to short in a 6.0 ltr block.
Old Mar 3, 2010 | 04:32 PM
ZONES89RS's Avatar
In-Zane Moderator
Yea, not sure, i know the crank is the same stroke, so you would THINK the rods would be the same length.
Old Mar 3, 2010 | 04:52 PM
boosted4life's Avatar
All I know if the 6.0 is a larger bore but same stroke as an ls1.
Old Mar 4, 2010 | 10:20 AM
redz_02's Avatar
Then again, if you have a stock crank checked out, they can take pretty much anything. Rated at up to 700 hp. Rods however, not so much.
