lq4 build question?
Old Mar 24, 2010 | 09:53 PM
dgcustomz's Avatar
Default lq4 build question?
O.k, I have done alot of searching but have come up with nothing I can see as far as my combo goes.
Here is what I have..
It's a 2001 Model Lq4 and I have some 243 heads unported but milled to 0.030 with patriot gold springs.
*What will my compression ratio be with these heads and mls head gaskets?
*What is the cc size on the 243's after being milled to .030?
Here is my plan... give me you .02cents please.
*Stock rebuild on the lq4. with arp head bolts and rod bolts.
*243's that are already milled 0.030 and also have patriot golds on them. I want to get them ported but by who and how much? I am on a budget as are alot of us on here. More than likely they won't get ported but I'd still like suggestions on who to port them and how much it will cost.
*Ported polished and shimmed ls6 oil pump
*Ls2 hd timing chain
*Fast 92/92
*fast fuel rails
*stock injectors? suggestions?
*Cam... still unsure? suggestions?
*I have a built t56
*TDP stage 3 clutch with lightweight flywheel
*Moser 12 bolt 33 spline with 4.56 gears
*Kooks 1-7/8 headers
*3" lanes true duals with moroso spiral flows, also have cut outs and I will be getting electric ones
*Slp 85mm maf sensor
*Ftp air lid
*Slp smooth bellow
*Also I am going to get a udp..brand? suggestions?
Any input and advice would be greatly appreciated, this is all going in my 2001 Camaro. I want the best combo for the most power with what I have already. Thanks in advance guys.
Old Mar 25, 2010 | 07:08 AM
ZONES89RS's Avatar
In-Zane Moderator
The compression will be between 10.5 and 11 to 1 i think, not sure on the CC, you will have to have a machine shop CC the chamber for it to be a accurate number. As for the cam, i have a Trex and i love it, i have 4.30 gears and the car works well with the combo, so the 4.56 is not a must if you want to back it down a touch. Get the heads ported if you can, it will be worth it.
Old Mar 25, 2010 | 09:26 AM
dgcustomz's Avatar
thanks zones, anyone recommend a shop to get the heads ported local in the dfw? Also My 12bolt moser is still at tdp and I have not ordered the gears yet and if you guys could chime in on the best gear ratio for the combo I would really appreciate it. Thanks
Old Mar 25, 2010 | 05:49 PM
ZONES89RS's Avatar
In-Zane Moderator
I say a 4.30, for me it seems to work best for a well rounded gear with a 6 speed, you can go with a 26 inch tall tire for the street or 1/8th mile and for the quarter or serious street a 28 inch tall tire, a 4.56 you would probably always want the 28 and that is not something i like to keep on my car usually, cost more too, i go thru tires too much to ALWAYS want the more expensive rubber.
