Little help with the C5.
I just bought a '99 Vette, Coupe, M6, 41K.
I'm really excited about the car in a whole. My mom took the car for the week and put a little over 1100 miles on it and now it has 43K.
I have a couple of questions about the car.
1. It has a pretty good wheel vibration at 70+mph. I think it is because the front left wheel has no weights on it that I can see or feel. I will be going to get the front tires balanced tomorrow 4/7 and will post up if this fixed it.
2. When I make a slight right turn there is a sound of a rub that seems to be really bad, and it is coming from the right, yet the further into the turn I go the better the sound gets. My family mechanic, who is a "good ole boy" said that it was probably the fact that it was only driven 2,000 miles the last 3 years the linkage is stiff and after time it will lossen up. I will be doing a 10-11 hour drive one way in 2 weeks and want to make sure this and #1 go away.
3. I hate the stock shifter and want to know how to take it off.
4. It has Depo headlights, and I need to know if they can hold HID's without the full harness or if I still need the relay.
Any help would be great
Thanks.
thanks, appreciated!
i got the kirban instead of the ripper, and with a short delrin vertical ****, its an awesome setup! might want to keep it in mind.
http://www.customstreetdesigns.com/6...-11B1PXAS1.htm
Thanks for your help with the Depo headlights, and the shifter and ****.
P.J.
P.J.
the arm is a tad high though, so if you put a ball or a c6 **** on it, i think it will sit high. thats why i got that delrin ****, because 3/4 of the length is threaded inside so it sits a good 1-2" lower than a ball.
