Roadforce balancing?
Old Apr 20, 2010 | 05:16 PM
FlashWS6's Avatar
Destroyer of Exotics
Default Roadforce balancing?
ive picked up some new iforge wheels, got them balanced at the local discount tire and everything was good til i went on the highway these thing shake hardcore above 55mph, i called iforge they said to look into roadforce balancing.
from what i understand its process that can take 2 to 3 hours to complete. has any1 ever had this process done?
or know a local place that can do it? located in houston texas
Old Apr 20, 2010 | 05:37 PM
LS1x2's Avatar
Formerly 4mulaJoe
I don't know this guy, but he wants his thread bumped. BUMP
Old Apr 20, 2010 | 05:40 PM
FlashWS6's Avatar
f*cken joe
thanks i guess
Old Apr 20, 2010 | 06:20 PM
DopeFedZ's Avatar
I have to find everything for my little b!tch.
http://www.gsp9700.com/pub/search/findgsp9700.cfm
Old Apr 20, 2010 | 08:24 PM
vicouSS00's Avatar
iforged huh bryan? sweeet. post pics fool
Old Apr 20, 2010 | 08:33 PM
5w20's Avatar
I can does it
Old Apr 20, 2010 | 08:37 PM
FlashWS6's Avatar
only have shitty pics, car is lowered now, once the caps show up il post pics
GTPM90's Avatar
most dealerships can do that. All it does is the balancer tells you how the tire should be positioned on the rim for the best balance,you rotate the tire were it says it needs to be then you add weights.
Old Apr 20, 2010 | 11:32 PM
02CamaroSSLE's Avatar
pm me, i work at discount and we have a road force machine, but i guarentee you, you dont need it, ill balance them RIGHT for you. in my personal opinion road force is a waste of time and money.
BINGO!
Old Apr 20, 2010 | 11:52 PM
95z28camaro's Avatar
and it may take only 5min longer total.... just depends how many have to be delfated and rotated on the rim. but still doesnt take longer than 2-3hrs lol as an ex discount tire employee myself, i agree that road forcing doesnt help much, unless its way the hell off, but usually the positioning of the tire on the wheel isnt the problem its most likey the tire at fault. you put a messed up tire on damn near perfect rim it aint gonna do **** for ya no matter where ya put it.... what tires are you running?
Old Apr 21, 2010 | 12:01 AM
well he mentioned iforged wheels so im thinking 18's or up... which means small and stiff sidewall which means they are a bitch to turn on the wheel, so chances are to turn the tire on the wheel you would have to take the top bead off, well bottom bead cause it's prob reverse mount, and turn the tire like that and then put the tire back on the rim. < pain in the *** but like i said before, prob wont do you any good, just need the **** balanced right.
Old Apr 21, 2010 | 07:37 AM
FlashWS6's Avatar
il let u take a stab it, if you fix it its cool hopefully your close.
i have a good friend of works at the store in la porte, he balanced my ccw's without any issue. so if you cant do it soon, i may have to make the drive to la porte lol which isnt far but ya know
Old Apr 21, 2010 | 08:36 PM
FlashWS6's Avatar
good meeting you thomas! happy with the job u did, only thing is the car still shakes but now only at 70+
Old Apr 21, 2010 | 10:02 PM
Turbo_Stang's Avatar
iForged = Baller.
Guess I need to start working the corner aswell
Old Apr 21, 2010 | 10:15 PM
tollway bandit 1's Avatar
Did you use the hub centric rings that come with then?
Old Apr 21, 2010 | 10:44 PM
the wheels were hub centric for the car. there were some thing wrong with it when i went to balance them today... the rears weren't balanced at all the fronts were counter balanced and the brake clips were still on and the wheel did not have a recess in the wheel... but iunno, thought i balanced them bad *** but i guess not...
Old Apr 23, 2010 | 01:39 PM
My wheels came with plastic rings. I was told that they make sure that the wheel is centered on the hub.
Old Apr 23, 2010 | 02:19 PM
FlashWS6's Avatar
i mean you did great it doesnt shake as much but its still noticable above 70mph.
at this point does any1 else have any other suggestions? if not il give the road force balance a try
Old Apr 23, 2010 | 06:15 PM
5w20's Avatar
Road force balancing will tell you if your tires or rims are bad. A lot of times I've seen aftermarket rims cause problems no matter brand they are. Cheap tires will cause issues aswell. Also there are idiots that use the big 1/2 ounce sticky weights and those always fly off. Calipers also tend to knock weights if clearance is close.
For smoothness its hard to beat an ugly oem wheel and a michelin tire.
Old Apr 24, 2010 | 01:20 AM
DopeFedZ's Avatar
Schmooth....
