clutch issues!!?
Old May 9, 2010 | 05:27 PM
black_byrdWS6's Avatar
Default clutch issues!!?
ok so my 96 ws6 had an empty resorviur so i added fluid but it still doesnt wanna go in gear its MCcloud stage 1. Anyone can tell me how to bleed the air out of the line hopefully that fixes the problem? oh yea and the pedal feels very lighter than normal when i push the pedal down? sorry for the mispelled words lol
Old May 9, 2010 | 05:38 PM
1_bad94Camaro's Avatar
fill the reservor to the full line then pump the clutch a few times then check to see if the level goes down. repeat until the reservor stays full. thats how i blead mine when i blew my slave cylinder apart.
Old May 9, 2010 | 05:41 PM
ok thanks i will go do that
Old May 9, 2010 | 06:31 PM
Ok so that didn't work damn it's frustrating!! Anyone do mechanic work or know of a good shop who won't butt rape.. It's something minor but I'm not sure what??
Old May 9, 2010 | 06:36 PM
whitehooptie's Avatar
That's not how to bleed an LT1 clutch. Fill it up, remove the slave cylinder from the tranny housing. Using your hand, push the pin in and out. As you push in, you'll feel air bubbles and crap being blown through. Keep doing it until you don't feel any of that stuff anymore.
Old May 9, 2010 | 07:17 PM
Ok so I can do it alone or do I need someone to push the clutch in!? By pushing the pin in and out that is what it is doing?
Old May 9, 2010 | 07:42 PM
it helps if you have a buddy to help. get under the car and remove the slave cylinder, then push the rod in with your had and release it. repeat until you dont feel any air bubbles passing through the slave cylinder. your buddy will keep putting brake fluid to keep the reservor from running out.
Old May 9, 2010 | 08:40 PM
Yes, if you suck in air, all that work you did was for nothing. I usually did it by myself. I'd pump 2 times, then fill the cylinder, 2 times and then fill the cylinder.
Old May 9, 2010 | 10:28 PM
Ok guys thanks very much I will try that tomorrow when I get off of work!!
Old May 9, 2010 | 10:31 PM
keep us updated bro. always trying to help fellow board members out.
Old May 10, 2010 | 07:03 PM
Ok so i have been going at it and still it wont go in gear? The pedal actually doesnt feel better either. Was any fluid supposed to come thru the boot ?
Old May 10, 2010 | 10:58 PM
No, if you have fluid coming through the boot, the cylinder is bad. Go to oriellys and buy a new slave cylinder. I think they're about $60 or so.
