car started knocking last night :(
No Bro no need for a new motor, do you have stock springs on the car? or after market? Either way you would want to get a spring and container kit. Its been a while since I've purchased one I think they are around $100-200.
I would pull the Valve cover to make sure its a spring, then call a local sponsor to get spring kit and replace them all since you got the cover off.
B
( so i took the cover off and none of the springs look cracked or bent
so i guess a lifter? wish sumone that knew more could come check it out but bieng broke cant pay nobody damn thus sucks! Have you thought about piston slap, injector cleaner, or checked your oil? Take a look at the pushrods, could be bent, and that can make some racket. Bouncing off the rev limiter can cause this.
I would say, change the oil and take a look at the drain plug. Only other method would be to do an engine tear down, and I think that would be overkill.
I also have 2 sets of stock springs that you can have if that's what's causing it.
