My first boat
Any recommendations for pitch? I think the current is a 21 and i am pretty satisfied with it, does 40 with 2 passengers and me, 35 with 3 plus me and the 2 YO, and when i brought the prop up a touch it went back to about 40.
http://s74.photobucket.com/albums/i2...9-15-06-06.flv
It's actually louder on the water believe it or not
Well, if it happens then it is time for the V8 right?
I have a 99 Larson with a 350 TBI . . . I've been looking at LS swaps for it. It's very easy, but the hardest part is deciding on a exhaust manifold
Well, i think i like that idea if i can get away with not having to run the exhaust out the engine, i think it can be done easily, i will have to look and see if i can just run it out the back of the boat with a couple of exit ports cut out. A 5.3 with a hot cam would be bad ***.
On the exhaust, you can plumb it out the back instead of through the outdrive BUT you need to obviously block the outlets that go through the outdrive. Mine has the Captains Call exhaust and you can switch it from through hull (Loud) to through prop (quiet). I wouldn't run a full hot exhaust, you still want the water jacketed exhaust to keep the temps down in the enclosed engine bay.
Forget the 5.3 or the 5.7 just drop a 6.2 liter in there!! Mine has the 320 HP 6.2 liter and good for about 65 mph in a 232 Baja Islander ....
In fact, we are heading out this afternoon for a little time out on the water!!
"I'm on a boat, look at me, I'm on a MF'ing boat"
Good luck and congrats on your new found fun!!!
Change the fuel filter while you're at it
It has a clear fuel filter, i am going to change it even though it looks like there is not much it it.
try cracking the gas cap to vent some air in
I have a 99 Larson with a 350 TBI . . . I've been looking at LS swaps for it. It's very easy, but%2
