Oil questions
Old Sep 6, 2010 | 11:32 PM
tjwwheel's Avatar
Default Oil questions
Alright so my oil light is always on, i check the oil and its just fine. So i just ordered a new oil sensor to see if that will fix it, however i ran into another weird thing. My oil pressure sensor is always off the charts, all gears and all RPMs, only time its below max is when im idling. What could this be from?
Old Sep 6, 2010 | 11:41 PM
westtexasbuff's Avatar
What weight oil are you using? Are you seeing change oil, or low oil? I think there's two... Also, did you reset your change oil light when you changed your oil? You're supposed to put the key to the front, and hold the trip mileage button thing on the speedo for 12 seconds...
Old Sep 6, 2010 | 11:43 PM
tjwwheel's Avatar
nooo its the low oil light not the change oil light. im just using regular ol' oil, non synthetic. 5w 30 i believe
Old Sep 7, 2010 | 11:53 AM
Might be a bad OPSU, I would change it with a GM one. The ones from Autozone or Oreilley's a lot of times are bad...
Old Sep 7, 2010 | 01:54 PM
tjwwheel's Avatar
aight! well im gonna try this oil sensor to solve problem #1 then i'll do the OPSU
