tq arm question
Old Nov 29, 2010 | 09:59 PM
dgcustomz's Avatar
Default tq arm question
I got a bmr extreme trak pak kit chassis mounted and I need subframe connectors to install it. Can I use 3 point subframe connectors? I need some info asap before I purchase, Thanks for any help
Old Nov 29, 2010 | 11:24 PM
Dirty 30's Avatar
from what I know you cant, but I think you can cut the cross bar shorter to make the 3pts fit.
Old Nov 29, 2010 | 11:25 PM
Dirty 30's Avatar
I used to have the trak pak and wolfe 2 pt SFC in my 30th back when it was running.
Old Nov 30, 2010 | 09:06 AM
dgcustomz's Avatar
Thanks Jesse. I'm gonna go ahead and order the bmr weld in subframes. Guy in houston has some slp 3 points cheap but i'd rather not make it harder than it is. Thanks for helpin us out the other night with the flywheel. We had the car on the lift and needed it done asap. Car is running alot better after that tune, we just need better tires.
Old Nov 30, 2010 | 09:30 AM
BadCompany VP WS6's Avatar
Wolfes mild steel SFC's are like $120ish I think. That's pretty cheap.
