Turnout/Bunker Gear
Opinions?
I priced the equipment I want and brand new it would be about $1250 meeting all NFPA standards from the 2006 update.
If I rent from the academy I will place a $200 deposit and then pay about 600 to rent.
All gear prior to 2006 met the NFPA standards of 1971. Equipment has been held to those standards and even exceeded standards since it was so long ago, but in 2006 new updates were put on those standards so anything manufactured prior to 2006 may not meet qualifications.
Depending on quality of equipment I could get full bunker gear ranging from 200-600 used (hopefully finding the right sizes and mixing and matching brands and colors)
Equipment consists of: hood, helmet, boots, pants, suspenders, coat and gloves
As I am sure you noticed, buying your own gear begins to add up quickly ~50 for a hood, ~150 for decent footwear, ~100 for gloves, ~250 for helmet, and so on. Those are rough estimates but you are going to drop quite a bit just for the bare essentials.
Like I previously stated, if I were in your situation I would go with the rented gear to make sure it is what you want to do. You can always purchase your own later down the road.
Volunteer departments, just like the paid services, will supply you with gear. Rent for your academy, and then have whatever department you join supply it for you! The only gear I'd consider buying myself would be good leather boots (if the department isn't paying for them and wants to only buy rubber boots) and a good helmet.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Thanks for all the advice guys! i'll rent my gear or I might even buy some used gear (found some pretty good prices on used gear that will meet academy standards and its cheaper than renting). I'll worry about having some nicer equipment once I get hired on
Once you get hired on a fire dept they will size you and get your own gear. The dept I work for even issues out our station gear and boots. We don't have to purchase anything.
If you go volunteer for a fire dept they will provide you some gear also.
I hope this helps you. If you have anymore questions just contact me I hope I can answer them
I was starting to fret about the price of new equipment but now my mind is at ease The Best V8 Stories One Small Block at Time
