How to clean a block?
Old Dec 17, 2010 | 05:35 AM
stevensLS1's Avatar
Default How to clean a block?
Hey guys I'm currently trying to build a LS1 coffee table. The block is quite dirty and wonder if you guys have an solutions to get the block cleaned. There's the normal dirt build up and such from a used motor ( 53K) I think. I've got access to a power washer if that might help. Thanks for any ideas!
Old Dec 17, 2010 | 05:39 AM
sleepersilverado's Avatar
can of engine degreaser or simple green. if you go with the engine degreaser be careful what you get it on that stuff is strong.
Old Dec 17, 2010 | 06:06 AM
lordrazo's Avatar
agree ^^^^ and a pressure washer you shouldnt have any problem post some pics of the table when done
Old Dec 17, 2010 | 06:29 AM
99zee's Avatar
A pressure washer with some degreaser will clean it up. Yes, post some pictures when finished
Old Dec 17, 2010 | 12:51 PM
stevensLS1's Avatar
Thanks again guys. I just have to find time to work on it! Damn christmas holiday's.
Old Dec 17, 2010 | 01:29 PM
Dirty 30's Avatar
Carb cleaner is better than engine degreaser.
Old Dec 17, 2010 | 01:49 PM
stevensLS1's Avatar
I was using that brakleen stuff and it work well but the hard baked on oil stains and stuff aren't easy to come off.
Old Dec 17, 2010 | 04:29 PM
Ravenous T\A's Avatar
U could always rattle can it since its only a table
Old Dec 17, 2010 | 06:31 PM
GoldRust's Avatar
LS1TECH Sponsor / 7 Second Club
The best thing to use is easy off oven cleaner. Spray it down, let it soak, then spray it off.
Old Dec 17, 2010 | 08:23 PM
Dirty 30's Avatar
trust me, carb cleaner will lift the paint right off your car lol it doesnt leave any oily residue and dries instantly. Use a rag or a light scotch brite pad to get the really thick stuff off. Carb cleaner is cheaper at wal mart. I think like $1 per can.
Old Dec 17, 2010 | 09:01 PM
redz_02's Avatar
Been watching top gear?
Old Dec 17, 2010 | 09:21 PM
1c62nv's Avatar
Gallon of that purple degreaser from Vatozone and a cheap set of bore brushes from Harbor and you got it
Old Dec 17, 2010 | 09:43 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Its awesome, all I use for those types of jobs. I bet the oven cleaner works well too.
Old Dec 17, 2010 | 09:59 PM
stevensLS1's Avatar
Sounds good guys. I'll try both of these. I'll try and finish this thing pretty quick with pics.
Old Dec 17, 2010 | 11:01 PM
Pwebbz28's Avatar
Take it to a machine shop and have it hot tanked. It will be SPOTLESS!
Old Dec 18, 2010 | 07:10 AM
1bad03snake's Avatar
+1 hot tank it or oven cleaner.. oven cleaner will take the stains off your driveway also
Old Dec 18, 2010 | 07:35 PM
stevensLS1's Avatar
How much will that exactly cost though? I got the block for $25.
Old Dec 18, 2010 | 08:06 PM
All-In's Avatar
From: Just because the voices aren't real, doesn't mean they're not right!
+1 The better shops have an enclosure with a rotating table inside and the chemicals used are aluminum-safe.
Old Dec 18, 2010 | 11:38 PM
drago1217's Avatar
53k miles...... ill trade you my 220k mile ls1 and pay to get it cleaned lol. If its in buildable shape
Old Dec 19, 2010 | 07:18 AM
vandejr's Avatar
i plan on doing the same, since the damn block i bought had a broken starter flange.
here are some ideas.
