pls help!!
Old Feb 12, 2011 | 02:45 PM
showstoMpinSS's Avatar
Default pls help!!
i have a 98 trans am and i tried sticking a 02 computer in there with the battery still hooked up and it would turn over but not start, so i stuck my 98 brain back in and now its doing the same thing, turns over but will not start, can anyone help?
Old Feb 12, 2011 | 03:55 PM
98Roller's Avatar
See what codes you are throwing with 98 Pcm...98 is not interchangeable with other years.
Old Feb 12, 2011 | 11:00 PM
WFOSS's Avatar
Did u check all of the fuses once u put the 98 pcm back in? You have a couple of ecm fuses and an engine sensor fuse as well. Also does the security lt stay on on the instrument cluster when the key is on? If so u may now have a body control module issue due to the vats system on our cars. Start with checking all of the fuses first.
Old Feb 13, 2011 | 05:05 AM
CarsandWomen's Avatar
did you re pin the harness with the swaps? this is an important question
Old May 13, 2012 | 07:50 PM
Todd Neyman's Avatar
if you swaped it you might have burnt something up, i did the same thing and my instrument cluster started smoking
Old May 13, 2012 | 07:53 PM
ProStreet_632's Avatar
Way to bring up a 15 month old thread....here comes the lock and key
Old May 15, 2012 | 01:43 AM
02CamaroSSLE's Avatar
how does that even happen? (bring up a thread that old and not even know it!?!?!)
