l92 in a T/A?
Old Mar 15, 2011 | 07:59 PM
showstoMpinSS's Avatar
Default l92 in a T/A?
i was wondering if anyone could tell me what all would i have to change to put a l92 in my T/A, i know i have to delete the vvt but what will i need to do, and around how much, any help is appreciated, thnx guys.
Old Mar 16, 2011 | 12:45 AM
AGRV8D's Avatar
all accessories, intake and the lingenfelter converter from how i understand it....
Old Mar 16, 2011 | 08:07 AM
Tootall's Avatar
what year L92 did you get . . . or is it just a 6L with L92 heads on it?
07 and up has a 58x reluctor wheel - if you have this, then you need the converter box
knock sensors are on the sides vs on top
cam sensor up front - needs extention harness
use your orginal accessories
some 07 and backs used the 24x wheel . . . that's a drop in
Old Mar 16, 2011 | 09:52 AM
Yes its a real l92, and its newer than 07 so ill need to get the converter, how would I delete the vvt? And will my 4l60e work?
Old Mar 16, 2011 | 12:45 PM
Tootall's Avatar
V.V.T . . . get a LS2 or 07 and up truck timing cover
reuse the front sensor
new 4x trigger cam gear
4L60e will work . . . but not for long
