2002 ss induction advice
Yes you will pick up power but for $2k you could probably find a better way to get the same power.
Just call some shops in your area and see what they think might be the best for you car and your needs.
Some foot work would be help full.
I know 400 hp might no be much. ( more than im making tho)
but compared to some other ls1tech guys. 400 hp to the ground is easy.
I say maybe some suspension work? maybe some weight loss if its not DD
A 92/92 can pick up quite a bit depending on your set up which seems to be working well.
What gears are you running? Still on the 10 bolt? Is it a A4 or M6? What was your 60'?
Man up and get a BIG cam to go with all that air flow.
Could go the larger cam route, but your setup seems to be working well together.
Personally, I'd keep that $2k ready in case the rear decides its had enough.
