Need help! Frustration growin!!
Old May 16, 2011 | 12:45 PM
souljaboy9768's Avatar
Default Need help! Frustration growin!!
I have a 2002 z28 ls1/m6
Where to start I ran the check engine light and it came up random missfire. I took it to a local shop And they said it was cylinder 7. I changed plug, coil and wire and the miss has not went away. At normal idle their is a small miss but when I take off there doesn't seem to be loss of power. I notice when I'm on the highway at 70mph in 6th gear at 1500rpm check engine light turns on. I can down shift till 5th and stay at 2000 rpm and the light immediately turns off. I notice a exhaust leak this morning coming from the driver side... I feel like I can't get rid of this problem soon I'll get rid of the car!! HELP please.
Old May 16, 2011 | 01:37 PM
k_dub09's Avatar
that would be something silly to get rid of your car for.... take it to a good shop that does dyno tunes and see if they can give you more of an in-depth scan than those that you'd get from autozone. my SS was doing something similar and it turned out to be condensation in the MAF, all it took was a hose clamp around the bellows that connected the maf and the lid to solve the problem. dont give up so easy!
Old May 16, 2011 | 01:47 PM
Bad Chad's Avatar
Sometimes an O2 can throw up a Mis-Fire
Old May 16, 2011 | 02:06 PM
I don't want to get rid of it, just drives me crazy..!
Old May 16, 2011 | 02:12 PM
5w20's Avatar
1)use a better scanner
2)check and make sure its mechanically sound
3)?????????????
4)problem fixed and PROFIT
Old May 22, 2011 | 01:18 PM
It was an exhaust leak, when I took my car to the dealer when they installed my driver side cat the broke a stud On the flang of the manifold. They didn't tell me I found out when I jacked up the car!! Drilled it out now it's good as new! Car running just like the first time I got in it! ThNks guys! This is the best site ever
