Service Engine Light
Old May 19, 2011 | 01:40 PM
WILDMN's Avatar
Default Service Engine Light
So the Service engine light came on... I took it to advance and had them run the codes because I have to get it inspected to transfer the title from Cali to Texas. The codes were... 2 of same code for small evap leak and 1 code for rear wheel speed sensor. It is a 2000 M6 T/A with T/C. Any ideas would be appreciated. I need to get it fixed fast so there are no penalties from the tax office. I have tried the auto parts stores and none of them carry the rear wheel speed sensor, at least not under that part name. Thanks in advance.
Old May 19, 2011 | 03:15 PM
Bad Chad's Avatar
Take it to a tuner and get the Evap system deleted. You may be able to clean the wheel sensor to get it to work properly.
Old May 19, 2011 | 03:23 PM
WILDMN's Avatar
I will try both of those suggestions. Thank you.
Old May 19, 2011 | 03:28 PM
DarknessHunter's Avatar
i had code for the sensor to got it deleted and nvr came back up
man your having all kinds off issues with this thing
Old May 19, 2011 | 04:12 PM
Slash8915's Avatar
I had a TON of random issues with my car for a while there (just ask G-force). They took care of me though, and I haven't had any problems since. (knock on wood)
Old May 20, 2011 | 01:49 AM
cowboysfan's Avatar
the speed sensor is on top of the rearend left side. easly to remove cause ther is only one bolt to remove and inspect. it is a magnetic type so you could have some impending failure on your rearend. other words some metal shavings can abstruct the continuity of the magnet to teeth from the ring gear. evap leak is usually from gas cap seal.
Old May 20, 2011 | 09:06 AM
1sicklsx's Avatar
I would inspect the speed sensor (may also be called vehicle speed sensor) and if nothing visually there then would replace it. As for the evap leak it could be gas cap seal, vent solenoid failure, or purge solenoid failure. Those are the most common issues with evap leaks besides a leaking hose!
Old May 20, 2011 | 10:13 AM
WILDMN's Avatar
The sensor it says is for my T/C... So that should be the one on the passenger side wheel with the magnetic pickup for the reluctor ring correct?
Old May 20, 2011 | 10:14 AM
WILDMN's Avatar
Yeah... Thats what happens when you buy one REAL cheap for a project I guess... But I wanted it to be at least a driving project lol.
Old May 20, 2011 | 04:33 PM
5w20's Avatar
100% this
that way you don't have to fix the stupid evap garbage and shouldn't ever have to worry about it setting another code in the future. Minus whale also get the other emissions stuff deleted as well.
I would also try and clean the sensor because that might work but it might have something to do with your axles being messed up though. Aren't you the guy that had problems with them?
Old May 20, 2011 | 06:36 PM
WILDMN's Avatar
Yeah. I am ordering the new axles... The ring looks fine though. Might have something to do with the fluid on it right this second though.
