overheating???
Old Jun 6, 2011 | 10:59 AM
speedZ28's Avatar
Default overheating???
I have a 96 camaro lt1 just rebuilt motor do to knocking so I built me a 383 to put back in it everything is swell except win ur driving it bout ten miles the temperature gauge will go up to red come back down to half way back up then back down then win car is at idle its around 160 wtf!!! So some advice would be great and other stuff to look for getting pissed of at it!!!
Old Jun 6, 2011 | 11:23 AM
03Sssnake's Avatar
Could be several things or combination. Make sure the system is bled properly, check fans, make sure you aren't missing the lower air damn under the front fascia. Without it the radiator will get no air when the car is moving.
Old Jun 6, 2011 | 01:15 PM
speedZ28's Avatar
Front fascia on fans are staying on but the blender valve spraying out a steady stream wtf think water pump it did seat up for two months in the shop but it was good win I pulled it off ne more suggestions
Old Jun 6, 2011 | 01:34 PM
Ravenous T\A's Avatar
Burp the radiator, sounds like u may have air in your coolant system.
(Add enough water and DEX-COOL™ engine coolant, meeting the GM specification 6277M in order to provide a solution that is at least 50% antifreeze, but no more than 70% antifreeze. )
1.Add enough water to fill the cooling system.
2.Run the engine until the thermostat opens.
3.Stop the engine. Repeat the steps in the draining procedure until the drained fluid is nearly colorless.
4.Remove, clean, and reinstall the coolant recovery reservoir
5.1. Close the air bleed vent when the bubbles disappear and only the coolant is visible.
5.2. Fill the radiator to just below the filler neck.
5.3. Fill the coolant recovery reservoir to the FULL HOT mark.
5.4. Add two cooling system sealer pellets, GM P/N 3634621.
5.5. Install the reservoir cap.
With the radiator pressure cap removed, run the engine until the engine reaches normal operating temperature
With the engine idling, add engine coolant to the radiator until the coolant level reaches the bottom of the filler neck
Old Jun 6, 2011 | 01:38 PM
Obie99ss's Avatar
Your thermostat might be getting stuck.... I would also check and make sure your water pump isn't leaking. It could also be the temperature sensor also. I had the same problem with mine in my 96 z28....
Old Jun 6, 2011 | 01:55 PM
speedZ28's Avatar
I would think the pump is working it not totally in the red so would think its moving water and the temp senser that's to tell computer to turn fans on rite one more thing pellets Wth is that lol radiator pellets Wats that do
Old Jun 6, 2011 | 02:00 PM
sorry, calm down....its just a breakdown on radiator filling from the GM Service Book. Pellets that GM sold I think were to help with Corrision I think, but u can ignore that and follow the other directions there Turbo
Old Jun 6, 2011 | 02:47 PM
speedZ28's Avatar
Thank u brother ill do it rite after work just first motor build and u think it goes rite but u always have bugs lol thanks again brother!
Old Jun 6, 2011 | 03:21 PM
U'll learn nothing goes according to plan...good luck. Work with the simplest fix then towards the hardest.
Old Jun 6, 2011 | 03:37 PM
cambirdracing's Avatar
Damn, that **** gave me a headache trying to read it.
Old Jun 6, 2011 | 03:57 PM
see sometimes Hulk Hogan needs help workin on cars too
Old Jun 6, 2011 | 09:55 PM
speedZ28's Avatar
After all the flushing water through it was the radiator put new one on good as new thanks again guys for the help!!
