Electrical System Issues
Old Jul 29, 2011 | 09:17 PM
Shackleford's Avatar
Default Electrical System Issues
For the past few weeks or so, the stereo would just cut off. It would come back on intermittently and then usually stay on. I would just wait for it. Today, however, I did it when I was in a drive-thru. I tried to roll down the window to order, but it didn't work. Right after I said screw it and drove off, the stereo came back on, so I tried to roll down the window. It worked. Any ideas?
Old Jul 29, 2011 | 09:48 PM
zamora7's Avatar
BCM. Behind the glove compartment, mine is starting to do it more often. It sucks since my A/C is not working yet.
Old Jul 29, 2011 | 09:50 PM
What does a good used one run?
Old Jul 29, 2011 | 10:08 PM
zamora7's Avatar
No idea man
Old Jul 29, 2011 | 11:59 PM
bassplayer103's Avatar
Do a search on here and you will find where some people have removed the BCM and used a soldering iron to fix it.
I had someone solder the damaged metal where the picture below is circled and it fixed the problem that you are describing.
Good luck!
Old Jul 30, 2011 | 12:02 AM
whitehooptie's Avatar
It's either the BCM or the ignition switch on top of the steering column.
Old Jul 30, 2011 | 09:38 AM
How do I determine if it's the BCM or ignition switch?
Old Jul 30, 2011 | 06:19 PM
slayer_taunu's Avatar
if you are having issues with both the radio and windows, it is the BCM. i had this problem and just re-soldered the appropriate joints and now all is good. you can just re-heat the solder joints, but i put a tiny bit of extra solder on there just to make it a little stronger.
you can see the solder joints in the picture that bassplayer posted, but if you do a search, there is a whole writeup on it.
