shipping engine/trans
If anybody's been down this road and can give me some pointers I would appreciate it.
Thanks!
Thanks!
Depends on what kind of condition you want it to be in when it arrives. Make sure to use heavy duty pallets. If you are shipping engine and transmission this will require two pallets joined together. Build a base for the engine to sit centered on and use ratchet straps to secure it to the pallet. Make sure you drain all the fluid from the motor and transmission. Use a few latex gloves and rubber bands to put over the tail shaft of the transmission to keep any left over fluid from dripping out. Cheapest shipping rate will be to drop it off at origin shipping station and have the consignee pick it up at destination facility.
