fuel pump question ........again
Old Aug 28, 2011 | 01:49 PM
bloo4.6's Avatar
Default fuel pump question ........again
ok so last week i had a fuel pump that was giving me hell (only 30 psi at WOT) so i was told it was a walbro 255 and what do ya know the previous owner lied once again, so i have the walbro in and the car still wont start after its hot, takes 2 or 3 times of cranking and it still barley starts, then this morning tried to start it and nothing just cranked and cranked.
Then went back later and fired right up,has 55psi pressure. So what am i missing, ive noticed that when i take the gas cap off a rush of fumes come out but its always done that
Old Aug 28, 2011 | 02:16 PM
9Green-Z8's Avatar
did you put a hotwire kit if not you should put a racetronix hotwire kit
Old Aug 28, 2011 | 02:53 PM
bloo4.6's Avatar
yeah did that also
Old Aug 28, 2011 | 02:56 PM
ramairracer's Avatar
is it a 98 with the metal sender
Old Aug 28, 2011 | 04:15 PM
bloo4.6's Avatar
well its a 95 lt1 w/ a 2000 motor im pretty sure it was just the stock pump
Old Aug 28, 2011 | 09:09 PM
i wonder what fuel sender is in it, since the LT1 factory has the fuel regualtor at the fuel rail while a 98 has a regulator in the sender assm, while the newer 99+ have the new style plastic pump and bucket,
sounds like you need an access door cut into the back so you can see what you have and we can go from there
Old Aug 30, 2011 | 07:22 PM
bloo4.6's Avatar
its has the stock lt1 unit but it has the corvette style filter that has a return in the filter
Old Aug 31, 2011 | 09:06 AM
AffordableAutoworks's Avatar
Feel free to bring it by the shop Thursday or Friday and we can isolate the issue.
 Michael S. Palmer
Old Aug 31, 2011 | 11:11 AM
00pooterSS's Avatar
Did it have fuel PSI when it didn't start? You only specified that it did have pressure when it did start.
When a car does not want to start when hot it is generally due to fuel metering (metering not supply) as in a improper signal from a temp sensor, MAF or MAP sensor, or maybe something in the tune. Engine sensors like cam and crank sensors are a fairly common problem on vehicles that have a hot start issue as well. I haven't heard of it really on LS1 cars but I wouldn't rule it out either.
Old Aug 31, 2011 | 11:15 AM
Dirty 30's Avatar
This...
Old Aug 31, 2011 | 01:32 PM
bloo4.6's Avatar
well im trying to find someone to tune the car right now, but yeah has fuel pressure at start up but like i said when its how it cranks and cranks forever. but when its cold it fires right up with no problem
Old Aug 31, 2011 | 03:15 PM
00pooterSS's Avatar
Not sure if that answered what I was asking but another idea is that now you have nearly double the fuel pressure you did before, so you are dumping a lot more fuel. It may have been tuned before with low fuel pressure. So its very likely it is dumping way to much fuel now. The way fuel metering works is to dump more fuel when cold to aid with cold start. Try holding the gas pedal down about 10-20% while cranking it, this will allow more air in to mix with the fuel and it will probably fire right up. Basically it is flooding so it needs more air.
Old Aug 31, 2011 | 06:24 PM
bloo4.6's Avatar
tried that still nothing just cranks and cranks and it has fuel pressure when it doesnt start
Old Sep 1, 2011 | 07:56 AM
bloo4.6's Avatar
so last night i hooked up mt pressure gauge and at idle i have 60 psi and at wot i have 55, not when i killed it and tried to start it back up it wouldn't start and it has 60 psi, so then i was just gonna unhook the pressure gauge so i bled off the pressure and the car fires right up after that ? I tried it a few more times and every time i bleed off a little pressure it fires right up ? could the injectors be locking up ?
Old Sep 1, 2011 | 09:10 AM
00pooterSS's Avatar
Not under 60 psi, probably if you were pushing like 200. I have ran well over 100 psi to injectors before with no problems using a FMU on a turbo integra.
Try holding the pedal to the floor and cranking it, get all the air you can in to mix with the fuel and let us know how that works. It's starting to sound like a possible tune issue. Which you need to have it tuned anyway if you now are running more fuel pressure.
Old Sep 1, 2011 | 08:28 PM
bloo4.6's Avatar
well tried the pedal to the floor and it doesnt start at all, the car runs strong as hell for what it has and then one day it started to lean out, so thats when i discovered that the fuel pressure was dropping off and right around the same time i started having starting issues with the car. im working on the tune but trying to figure out why all of the sudden it doesnt want to start first
Old Sep 1, 2011 | 08:47 PM
mred's Avatar
you have a line bent some where,check the lines coming into the top of the pump inlet.
make sense?
Old Sep 1, 2011 | 09:08 PM
00pooterSS's Avatar
Oh okay now I see. Well man I don't know, random question is the temp guage working? And is the plug on the side of the head plugged in for the temp sender? It's on the drivers side head at the front. Mine came unplugged one day and it didn't want to run for ****.
Old Sep 1, 2011 | 11:46 PM
Sam88Gta1's Avatar
Sounds like its less to do with the fp and more to do with the tune.
I never heard from you about tuning the car. Do you still have my number?
Old Sep 2, 2011 | 08:14 AM
bloo4.6's Avatar
yeah ive pm'ed you and call and left messages ??? need to get it done asap
