need opinions
thanks
what were the rings gapped at if it was "built for boost"? what size are the pistons? That's going to make a difference in its n/a power. also if your new compression is still 9:1 with the new H/C you can run more timing.
go here to find your new static compression, b/c i dont see it being 9:1 with the LS6 heads.
http://www.rbracing-rsr.com/compstaticcalc.html
Cylinder Head Volume - 317 - 71.06 cc
Piston Head Volume - Stock - 0.00 cc
Gasket Thickness - Stock - 0.052 in
Gasket Bore - Stock? - 3.785 in
Cylinder Bore - Stock - 3.780 in
Deck Clearance - Stock - (-)0.010 in
Stroke - Stock - 3.27 in
Static Compression Ratio - 8.632:1
Cylinder Head Volume - 243 - 64.45 cc
Static Compression Ratio - 9.332:1
If you can give me or find me the exact specs on your deck clearance, gasket thickness, and gasket bore, I can be more specific.
