Suspension Advice
Old Feb 6, 2012 | 12:10 AM
WILDMN's Avatar
Default Suspension Advice
I was underneath my car today taking a look at my exhaust and noticed that one of the rubber bushing that hold it dry-rotted... That explains the exhaust making noise... but I also discovered my front coil over's are leaking and I know my rear shocks are going out.
So my question is:
What shock/strut setup to go with? I already have LCA relocation, subframe connectors, adjustable torque arm and relocation. The car also has true duals which cause some clearance issues and will be getting LT's. I do not know if lowering it will be a good idea because of these factors since clearance has proven to be an issue a couple of times already on the true duals. I was thinking QA1, but if I get them I do not know how to adjust them properly.
Old Feb 6, 2012 | 07:18 AM
DPRock's Avatar
Make sure you get the bearing and spanner wrench kit for the coil overs makes adjusting them much easier. Or just order the wrench and find 2 e4od forward planetary bearings must be from steel planetarys. Most transmission shops should have them 1.00-3.00 should be the most you pay for the bearings.
