Brake shop in DFW???
Old Feb 17, 2012 | 12:11 AM
blazzin93z's Avatar
Default Brake shop in DFW???
Hey guys. Just got down in the DFW area and I need to have my rotors/pads changed on my 2002 z28. I purchased some Breakmotive Pads/rotors from the forum deal on here, and I was just looking for a good shop that can install them and bleed the lines. Any help would be appreciated in advance.
Old Feb 17, 2012 | 07:48 AM
Greed4Speed's Avatar
Brakes are easy. DIY. Other than that, any shop could do this.
Old Feb 17, 2012 | 08:40 AM
slayer_taunu's Avatar
changing pads/rotors is def a DIY job... if you've never done it before, post up where in DFW you are, and i'm sure there's someone near you that will give you a hand.
as far as bleeding lines.... you can DIY as long as you dont have air in the ABS block. then you have to go to a stealership and they have to cycle the ABS block solenoids with a Tech2 tool.
