Radiator Upgrade
Old May 16, 2012 | 03:15 PM
cajunss's Avatar
Default Radiator Upgrade
Looking to replace my stock Radiator and thinking about going with the BeCool
134-62028 has anyone of you installed this model is it a direct fit no cutting or modding anything to make it fit? I looked at the specs and it look as its wider and higher than the stocker. So I'm wondering if I would have to mod anything to make it fit? Just want to make sure before I order one. Thanks
Old May 16, 2012 | 05:26 PM
KWIKKAR's Avatar
Id like to know as well...
Old May 16, 2012 | 09:18 PM
ppp's Avatar
ppp
There is a dirt track magazine, DayMotorsports, that has dual pass radiators for dirty cheap that work bad ***!
Old May 17, 2012 | 07:48 PM
WILDMN's Avatar
I have a ebay all aluminum radiator on order. I will let you know how it goes when I get it installed. It only works with 6 speeds though because it does not have a tranny cooler built in.
Old May 17, 2012 | 08:04 PM
02sleeperz28's Avatar
I would like to know as well. What do you guys with ls cars think about upgrading to a lt1 radiator?
Old May 17, 2012 | 08:06 PM
WILDMN's Avatar
Mine had the LT Radiator in in. It still ended up cracking. That why I am going to try this now. The LT radiator will be coming out and I am sure it can be repaired. I just want to go a different route.
Old May 17, 2012 | 08:28 PM
cajunss's Avatar
I would like to get the Becool, But hate to have to cut anything to make it fit. Trying to find out if that is the case are not.
Old May 25, 2012 | 02:08 PM
killerwhale's Avatar
here u go, i didn't cut anything
Attached Thumbnails Radiator Upgrade-imag0188.jpg   Radiator Upgrade-imag0189.jpg
Old May 25, 2012 | 06:13 PM
SHovV's Avatar
I have the be cool 60246 and meziere electric water pump. No fitment issues at all
