dash problem
Old Jul 12, 2012 | 08:39 AM
showstoMpinSS's Avatar
Default dash problem
i was wondering if anyone could help me, my gauge cluster comes on and lights up but the rpm, temp, and fuel gauge do not work. The speedomoter, and battery do however, also pretty much all the lights are on. I recently changed the head gaskets and i know i hooked up the three grounds on the back of the head, but im wondering if maybe one needs to be cleaned somwhere or somthin, any suggetions will help. Thnx
Old Jul 12, 2012 | 09:57 AM
DopeFedZ's Avatar
Make sure you didn't cut one of those wires or break any off the ring terminals.
Old Jul 12, 2012 | 10:09 AM
I made sure and checked them both with a test light, still nothing
Old Jul 12, 2012 | 10:59 AM
jiveass's Avatar
i had that problem after my engine swap...ran a ground from the chassis of the ecu to a bolt on the fender well...problem solved.
Old Jul 12, 2012 | 02:38 PM
So I need to ground the metal housing of the ecu to the body?
Old Jul 12, 2012 | 04:00 PM
I forgot to mention the elec fans are not kicking on either
Old Jul 12, 2012 | 04:35 PM
DPRock's Avatar
make sure you didnt ground all three to one bolt. ive heard it will cause problems.
Old Jul 12, 2012 | 08:39 PM
The ground to the PCM did not work, i have no idea what it could be
Old Jul 13, 2012 | 09:02 PM
Any other ideas? Anything helps
Old Jul 13, 2012 | 09:29 PM
DopeFedZ's Avatar
What else did you unplug? Did you mess with any of the connectors on the passenger fender well or the ones under the passenger side kick panel inside the car?
I know you said you remember connecting the grounds on the head just check again and make sure none got cut.
Sounds like a connector got left unplugged somewhere.
