**RHS 445ci Engine Dyno Video**
Old Aug 9, 2012 | 10:18 AM
Worm Boy's Avatar
Arrow **RHS 445ci Engine Dyno Video**
This engine is going in an 08 Z06 built purposely for road racing. We will start engine install/build next week so be checking back for in car results.
Engine made 775hp with cast manifold, engine will be getting sheet metal intake when it gets installed in vehicle.
Enjoy!
http://youtu.be/gQAqe7CtHlQ
Old Aug 9, 2012 | 10:52 AM
Turbo_Stang's Avatar
Where will the bar stop?
Cars are getting crazy fast.
Old Aug 9, 2012 | 02:42 PM
ZO6ER's Avatar
Nice, can't wait to see that hood on it.
Old Aug 10, 2012 | 09:04 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Killer engine. Who makes those valvecovers?
Old Aug 10, 2012 | 11:39 AM
BADZ's Avatar
Moderator
Looks kinda like a polished Katech cover.
Old Aug 10, 2012 | 04:43 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Katech are cast aluminum, those appear to have machining marks - like they are billet. Maybe a newer version of Katech?
Old Aug 11, 2012 | 01:05 PM
Inspector12's Avatar
TT-TECH Veteran
Nice build. Is that the Moroso Vacuum pump mounting bracket and pulley set up? I don't think those are Katech's but look really close in design.
Old Sep 20, 2012 | 12:54 PM
Worm Boy's Avatar
She is ALIVE...Initial start up.
http://youtu.be/R9iLloxOebA
Old Sep 20, 2012 | 01:22 PM
| Powered by Satan |'s Avatar
going to be a monster
Old Sep 20, 2012 | 05:09 PM
Kingsize's Avatar
Hey Steven, how are you guys controlling both DBW throttle bodies? I really need that if you can pass along some info. A PM would be fine if needed.
Thanks, Jason
Old Sep 20, 2012 | 07:59 PM
LSX-coupe's Avatar
I believe the pro efi allows the use of dual DBW TB. I know the Holley Dominator will allow it.
Old Sep 21, 2012 | 09:17 AM
jmilz28's Avatar
Twin throttle bodies...muddafuggin pro. Nothing less expected from LMR. Exquisite build, gents.
Old Sep 21, 2012 | 03:30 PM
SHovV's Avatar
That looks pretty awesome
Old Sep 21, 2012 | 04:41 PM
ZO6ER's Avatar
In for dyno numbers.
Old Sep 21, 2012 | 06:02 PM
Worm Boy's Avatar
After first day of dyno pulls with 93 Octane pump gas I got 698rwhp with 22* of timing. I will be draining the tank monday morning and going with C16 so I can put some timing in it to see where the final numbers are at. I am shooting for 730rwhp, which for a Naturally Aspirated setup will be pretty incredible.
Yes, the twin throttle bodies are wired directly into the PROEFI box. The factory computer is still on board to control factory gauges. This car will have the luxury of having a switch the customer can hit to change from pump gas tune(for weekend cruising) to race gas tune (for the track).
Definitely the strongest Naturally Aspirated Corvette LMR has built to date! We have a GTO being assembled now with a very similar setup. Will be interesting to see those results with a little smaller cam shaft.
Will post up dyno videos and graphs beginning of next week.
Old Sep 22, 2012 | 11:13 AM
venom ws7's Avatar
Amazing work like always 700rwhp N/A sick.
What heads? Compression?
