Caliper Bolt size Dimension/part#?
Old Aug 27, 2012 | 09:55 AM
Z28GONZO's Avatar
Default Caliper Bolt size Dimension/part#?
Thats what i need my car broke down on my way to work yesterday. from the looks of it the caliper bolt broke off and the caliper itself was swinging around in the wheel causing damage all the way around. im in the Academy in Austin to become a State Trooper and am locked in until the weekend. if some one can help that would be great. hoping to stop by and hopefully fix it friday afternoon.
Old Aug 27, 2012 | 11:19 AM
ROCNDAV's Avatar
Which caliper (front or back)? and which bolt? Caliper to pin?
Old Aug 27, 2012 | 11:36 AM
ROCNDAV's Avatar
I'm assuming #2(front) or #14 (rear)?
Front Brake caliper:
1. Housing, FRT BRK CLPR (Part of Kit 1).........................................NPN
2. Bolt, FRT BRK CLPR Guide Pin (Part of 10, Kit1, Kit2, Kit3) M8x1.25.....(4)...18026153
3. Cap, FRT BRK CLPR Bleeder valve (Part of Kit 1)...............................NPN
4. VALVE, FRT BRK CLPR Bleeder Valve (Part of Kit 1).......................(2)...18029799
5. SEAL, FRT BRK CLPR Bleeder valve............................................. .NPN
6. PIN, FRT BRK CLPR GDE............................................... ....(4)...18026161
7. SPRING, FRT BRK SHOW A/RTL (includes 2 springs) (Part of Kit3)..........(2)...18026181
8. SEAL, FRT BRK CLPR GDE PIN..............................................( 4)...18026151
9. PAD, FRT DISC DRK INNER (Part of Kit3)........................................NPN
10. BRACKET, FRT BRK CLPR (includes 2, 11)
98-02 (J65, EXC Z4C).............................................. ..(2)...18026163
02 (Z4C)............................................. ...............(2)...18046301
11. SHIM, FRT BRK PAD (Anit-Noise) (Part of 10, Kit3) (Includes 4 shims)....(2)...18026164
12. PAD, FRT DISC DRK OUTER (Part of Kit3)........................................NPN
13. PISTON, FRT BRK CLPR (Part of Kit1).....................................(4)...18 026162
14. BOOT, FRT BRK CLPR PSTN (Part of Kit 1, Kit2).................................NPN
15. SEAL, FRT BRK CLPR PSTN (Part of Kit 1, Kit2).................................NPN
Kit1 CALIPER, FRT BRK (includes 1-4, 13-15)
98-02 (J65, EXC Z4C).............................................. ..(LH)..18042491
98-02 (J65, EXC Z4C).............................................. ..(RH)..18042492
02 (Z4C)............................................. ...............(LH)..18046299
02 (Z4C)............................................. ...............(RH)..18046300
Kit2 CALIPER KIT, FRT BRK (includes 2, 14, 15)
Kit3 PAD KIT, FRT BRK (includes 2,7,9,11,12)
98 (J65)............................................. .....................18026165
98-00................................................ .....................18038574
99-02 J65............................................... ..................18026293
Rear :
1. Bracket, RR BRK CLPR (On Caliper).......................................(2) ...12456459
2. SHIM, RR BRK PAD (Part of Kit 1)..............................................NP N
3. PAD, RR DISC BRK OUTER (Part of Kit 1)........................................NPN
4. PAD, RR DISC DRK INNER (Part of Kit 1)........................................NPN
5. Housing, RR BRK CLPR (Part of Kit 1)..........................................NPN
6. SEAL, RR BRK CLPR PSTN (Part of Kit 2, Kit3)...........................(2)....12530709
7. BOOT, RR BRK CLPR PSTN (Part of Kit 2, Kit3)...........................(2)....12530707
8. PISTON, RR BRK CLPR (Part of Kit2).....................................(2)....1 2453509
9. Cap, RR BRK CLPR Bleeder valve (Part of Kit 2)................................NPN
10. VALVE, RR BRK CLPR Bleeder Valve (Part of Kit 2).......................(2)....14071826
11. SPRING, RR BRK ANTI/RATTLE (Part of Kit1, Kit2)...............................NPN
12. BOOT, RR BRK CLPR Guide Pin (Part of Kit3)..............................(4)...12530703
13. PIN, RR BRK CLPR GDE............................................... .....(4)...18026161
14. BOLT, RR BRK CLPR (Part of Kit1, Kit2, Kit3)............................(4)...14067559
Kit1 PAD KIT, RR BRK (includes 2-4,11,14)
98-99 (J65)............................................. ..................12454972
98-99................................................ .....................18039835
00 (J65) 1st design, use for VINS prior to 2G1FP22K6Y2100381).............18038575
00 (J65) 2nd design, use for VINS after 2G1FP22K6Y2100381)................12454972
01-02 (J65)............................................. ..................12454972
Kit2 CALIPER, RR BRK (includes 5-11, 14)
98-02 (J65)............................................. ............(LH)..12455127
98-02 (J65)............................................. ............(RH)..12455128
Kit3 REPAIR KIT, RR BRK CLPR HYD (includes 6, 7, 12, 14).....................(2)..12530687
Attached Thumbnails Caliper Bolt size Dimension/part#?-brake-caliper-front-98-02.jpg   Caliper Bolt size Dimension/part#?-brakecaliper-rear-98-02.jpg
Old Aug 27, 2012 | 11:53 AM
Z28GONZO's Avatar
Was that #2 Front Thanks for the fast responce
