Quick Question...
Have a quick question, is there a how to write up on steps to change a power steering pump on a 99 Trans am?
Also Where is the How to section can't seem to find it
Happy holidays
-Brandon
Place a drain pan under the power steering pump (1)
Remove the air intake resonator and mass airflow assembly.
Remove the serpentine belt.
Remove the power steering pump pulley. Refer to Power Steering Pulley Replacement in Steering.
Remove the outlet hose and the clamp from the reservoir (This allows fluid to drain from reservoir).
Remove the inlet hose fitting from the pump.
Remove power steering pump attaching bolts (4) and power steering pump front brace (3) from pump (1)
Remove pump (1) from rear bracket (2).
Remove reservoir from pump. Refer to Power Steering Reservoir Replacement - Off Vehicle in Steering.
INSTALLATION PROCEDURE
Install reservoir to pump. Refer to Power Steering Reservoir Replacement - Off Vehicle in Steering.
Install pump (1), pump front brace (3), and attaching bolts (4) to rear bracket (2).
Tighten the bolts/screws to 25 Nm (18 ft. lbs.) .
Install the inlet hose fitting from pump.
Tighten the fitting to 28 Nm (21 ft. lbs.) .
Install the outlet hose and clamp to reservoir.
Install the power steering pump pulley. Refer to Power Steering Pulley Replacement in Steering.
Install the serpentine belt.
Install the air intake resonator and mass airflow assembly.
Remove drain pan.
Refill and bleed the power steering system. Refer to Bleeding Power Steering System in Steering.
Tools Required
J25034-B Pulley Pump Remover
Remove the air intake resonator and mass airflow assembly (LS1 only).
Remove the serpentine belt. Refer to Drive Belt Replacement (Accessory) in Engine.
Use the J 25034-B in order to remove the power steering pulley from the power steering pump.
Tools Required
J 25033-B Pulley Pump Installer
IMPORTANT:
3.8 Liter Engine: Ensure that the face of the pulley hub is flush with the end of the pump shaft before you apply a load to the pulley hub.
5.7 Liter Engine: Ensure that the pulley hub shoulder bottoms out completely on the pulley shaft before you apply a load to the pulley hub.
Ensure that the pulley goes on snug when installing the pulley with the special tool. If the pulley installs onto the pump shaft too easily, it will not relay engine power to the pump and should be replaced.
Use the J 25033-B in order to install the power steering pulley to the power steering pump.
Install the air intake resonator and mass airflow assembly (LS1 only)
Install the serpentine belt. Refer to Drive Belt Replacement (Accessory) in Engine.
Check power steering operation and visibly check pulley for any irregular wobble when operating.
