Help.. ABS, Traction control and ABS lights
Old Feb 14, 2014 | 09:31 PM
Cdharley00's Avatar
Default Help.. ABS, Traction control and ABS lights
I have a set of 17" Billet Specialities on the front of my 02 Camaro SS and 15" with 275X60X15 Mickey Thompson on the rear. My problem is the traction control, ABS, and Brake lights stay on my dash. Is it because of the difference in wheel sizes. I understand this can't be tuned out of it. Does anybody know?
Old Feb 14, 2014 | 10:43 PM
codyvette's Avatar
It only matters if the outside overall diameter is quite a bit different. No they cannot be tuned out.
Old Feb 15, 2014 | 03:45 PM
42273's Avatar
im pretty sure if it was just your tires causing the the problem the red brake light wouldnt come on , this problem happens to me more often when its warm outside than when its cold. it just doesnt bother me enough to diagnos
Old Feb 18, 2014 | 05:22 PM
imma_stocker's Avatar
Mine did the same thing. So I made my own cluster LOL
Seriously though, BRAKE light shouldn't turn on due to anything but handbrake switch. Did you buy the car like this? Are you running stock 10 bolt?
