Removing a c5 axle back
Old Oct 24, 2014 | 09:03 PM
08-4door's Avatar
Default Removing a c5 axle back
Is there a trick t o remove the factory axle back on a c5 z06.i had it at a muffler shop and the could not get the pipe to come out over the trans.
Old Oct 25, 2014 | 11:06 AM
05 GSXR 1XXX's Avatar
Been a while but you need to loosen the rear sway bar or remove it. If you try this at home get the car crazy high.. Those mufflers have to rotate a lot
Old Oct 25, 2014 | 06:03 PM
RA032926's Avatar
this... if they are base mufflers you can just cut them off if you're swapping them out, they aren't worth squat anyway... if they are titanium you can get a few hundred for those so I would remove them in one piece
Old Oct 25, 2014 | 10:27 PM
08-4door's Avatar
Yes I took to a guy that knowed how to remove them.they cam off a 30k mile car what is the titanium axle back worth I'm going to put it up for sale.And I dont wanna sound stupid on a price.
Old Oct 25, 2014 | 11:47 PM
floman's Avatar
They usually sell in between $300.00 - $400.00 range. Price them cheap and they will sell fast, on the higher end may take a little longer.
Old Oct 26, 2014 | 09:45 AM
08-4door's Avatar
I'll start at 400 and go from there I guess
