Air coming through floorboard while moving
Old Jul 27, 2015 | 05:43 PM
Ballerado's Avatar
Default Air coming through floorboard while moving
So I'm assuming I have a vacuum leak or something somewhere dealing with the flappers for the floorboard. Faster I move, more air comes through. No other vents. Need a little help on where to start looking/replacing.
Old Jul 28, 2015 | 12:39 PM
Bad Chad's Avatar
On the back of the intake there is a vacuum port, make sure its plugged in...
My the computer there is a T with 3 lines attached to it, make sure they are connected too
Old Jul 28, 2015 | 03:13 PM
Ballerado's Avatar
Yeah I kind of figured that was a good starting point. I know I e changes out that little check valve where the vacuum lines meet by the pcm. But didn't do anything. The lines split off and go to different locations, is there a specific one that would be more specifically related to the floor vents if I'm all plugged up behind the intake? It's just to damn hot outside to have hot air from under the hood pour in.
