While the carpet is out...
Old Feb 7, 2017 | 10:13 PM
boofthese's Avatar
Default While the carpet is out...
What should should I get done ?
Old Feb 8, 2017 | 11:43 PM
joeformula's Avatar
Dynamat. I am currently doing this on my bird and I'm pretty confident it'll be worth the time.
Old Feb 9, 2017 | 11:36 AM
MY_2K_Z's Avatar
Yep I used snow king duct insulation.
Old Feb 9, 2017 | 12:00 PM
imma_stocker's Avatar
That's exactly what I've been using for 15 years. I also use some sort of additional adhesive like caulking to keep it stuck with maximum contact patch. Polyurethane stuff kept mine stuck to inner door skins, roof skin, etc and it basically peels off.
Then shove carpet padding into the dead spaces and add a layer under the carpet for that fancy plush feel.
That's how you sound deaden an entire car for about $50.
Add $10 or so if you want to fill in dead space with expanding foam. I've heard of panels pushing out with the foam but never seen it myself. Something like 3 cans in the Camaro right now lol
Old Feb 9, 2017 | 12:31 PM
MY_2K_Z's Avatar
3m spray adhesive helps if it's cold outside. I did it when it was nice and warm out so it stuck great and no peeling issues. I'm also thinking I want to put expanding foam in all the voids like rockers, qtrs, sail.
Old Feb 9, 2017 | 02:44 PM
2ToeRacing's Avatar
On the dynamat.....what parts of the car are you doing and how much is it costing you??? I've been wanting to do my car and my truck,anyway thanks Barry
Old Feb 9, 2017 | 09:15 PM
joeformula's Avatar
Barry, I'm doing virtually everything with the exception of the roof. Beneath the dash to the tailights and up the sides of the car leading up to the roof. Plus the doors. I purchased 108 sq ft (3 packs) of dynamat xtreme and I hope it'll be enough. 108 sq ft was about $450 and I'm looking forward to completing this and seeing what the difference sounds like
Old Feb 10, 2017 | 04:03 PM
Stew2000's Avatar
Does the snow king have sound deadening qualities as well?
Old Feb 10, 2017 | 05:52 PM
MY_2K_Z's Avatar
Yes it's a super dense rubber/foam it definitely take the tinny sound out.
