Houston PCM programming
Old Apr 4, 2017 | 08:44 AM
OxTheGreat's Avatar
Default Houston PCM programming
Hey guys, looking for someone in North Houston to unlock/bench program my pcm. I need a basic tune to get engine running enough to test, leak check and run until im able to take it for dyno tuning.
Specs are:
Gen 3 4.8 stock bottom end, ported heads and upgraded springs
224/224 .523/523 114+4 cam
E85 1000cc injectors
Borg warner S475/88
Will run engine without charge pipe installed until at dyno tuning
Old Apr 4, 2017 | 01:08 PM
jmilz28's Avatar
https://www.guerragroup.com/motorsports
Old Apr 5, 2017 | 10:44 AM
LSX Power Tuning's Avatar
Originally Posted by jmilz28
Patrick doesnt have a bench setup, we flash stuff on our bench setup for him.
Old Apr 5, 2017 | 10:52 AM
OxTheGreat's Avatar
how much do you guys charge for a basic bench tune?
Old Apr 5, 2017 | 11:09 AM
For stock or bolt on's it runs $150 for cam, heads, FI, N20, or engine swaps its $200. Your mods are WAY past just a basic bench tune. A lot of people have the misconception a bench tune is quick and easy, its the same amount work to build your bench tune as to tune it in person, we are just skipping the last step of data logging and fine tuning it.
http://lsxpowertuning.com/online-sto...=0&sort=normal
Old Apr 5, 2017 | 11:18 AM
OxTheGreat's Avatar
Touche on the basic part. Your completely right, its a pretty in depth task. So, i pay $200, send you guys my computer and specific specs on build and a couple weeks later i have a usuable tune. That sounds like an awesome deal to me. If im off, please correct me.
Old Apr 5, 2017 | 12:32 PM
It's all done though our online store. Just go to the website and checkout and send in your pcm along with the PDF file. We normally have a 3 day turnaround time but we closing today and re-opening on the 11th.
