00 z28 cooling problem
Old May 10, 2020 | 08:33 AM
ddinwiddie's Avatar
Default 00 z28 cooling problem
trying to find the best to troubleshoot my engine cooling issue in the houston area?
Old May 10, 2020 | 09:22 AM
RB04Av's Avatar
You could try https://ls1tech.com/forums/ls1-ls2-l...performance-3/, somebody there might be willing to help
Seriously, what sort of cooling issue are you thinking that you have?
Old May 10, 2020 | 09:24 PM
ddinwiddie's Avatar
still runs hot (over 230), fans both work, water pump new, heater bypassed, tried with or without themostat, radiator is only year old, and no leaks. I guess it some kind of flow issue but its been kicking my butt for a while now.
Old May 10, 2020 | 10:23 PM
Super obvious but gotta ask. Any possibility of entrapped air in the engine?
Old May 18, 2020 | 01:57 PM
imma_stocker's Avatar
Did you remove or break the lower air dam?
Old May 18, 2020 | 02:06 PM
Spamfritter's Avatar
I had this issue on a 2005 GTO. It turned out that the thermostat housing had a tiny fracture in it. Replacing that fixed the issue for me.
