Houston Machine Shop
I need a machine shop in Houston. I purchased a pull out LS3 for a project and the people who pulled it out sprayed it with a degreaser or something that has the block covered in an almost white powdery kind of substance. I replaced the cam in it but left the heads off too long and now the cylinder walls have surface rust. I need a machine shop recommendation that can pull it apart and clean up the outside of the block and clean up the cylinders then reassemble it and paint it.
Call and talk to them. Choose whichever you like the most. No matter who you choose, it is built by their employees and quality will only be as good as that person's effort.
ETA: He is outside of Tomball though.
