"brake" light???
Old Dec 10, 2004 | 06:25 PM
fastflames's Avatar
Default "brake" light???
anyone have the brake light come on for no reason? and I did check the e-brake. Thanks.
Old Dec 10, 2004 | 10:40 PM
1STGEN68-2000SS's Avatar
Check your brake fluid level. If it is low enough it will cause the same brake light to come on.
Alan
Old Dec 10, 2004 | 11:00 PM
KATN SS's Avatar
I wish I could help you, but my brake light doesn't come on at all, even with the e-brake engaged.
Old Dec 11, 2004 | 12:31 AM
BigSteele's Avatar
when I was installing a shifter on my 99 z28, I took the center console off and could see the parking brake assembly. At the bottom of the brake handle there is a little contact switch, I think its a ground, when the handle is down I think it connects the ground. When the e brake is not engaged I think it breaks a ground contact and I guess this goes to the gauge light. so if the switch if messed up, it may: a-not make the ground contact ever, signalling e brake is on, or b-always making the ground contact and e brake is always off.
I am not totally sure if all this is correct, I just saw the switch and assumed these things. Hope this info helps
Kenny
Old Dec 11, 2004 | 05:39 PM
fastflames's Avatar
Alan
Thanks you guys for the input. Seems like you were right Alan. First, I thought it was a problem with my SLP line lock, but I jumped the gun and forgot about the simple stuff. Checked the fluid level and it was very low. I filled to the recommended line and the light goes off with the ebrake down.
Old Dec 11, 2004 | 09:06 PM
5w20's Avatar
cool beans, problem solved
