T-56 Tailshaft plug
Old Jan 12, 2005 | 08:36 AM
BAD2000TA's Avatar
Default T-56 Tailshaft plug
Does anybody know where you can get a tailshaft plug locally for a T-56? Doing the clutch this weekend and don't want a mess and too lazy to drain the tranny!
Brian
Old Jan 12, 2005 | 08:59 AM
BRENTT94Z's Avatar
I typically just disconnect the drive shaft from the rearend and just leave in in the tail shaft while pulling the trans out. Are you using a lift or do you do it the way I do laying down on the ground?
Old Jan 12, 2005 | 10:32 AM
BAD2000TA's Avatar
On the ground! I'm assuming you took off your Y-pipe when taking out your transmission?
Old Jan 12, 2005 | 10:38 AM
BRENTT94Z's Avatar
Ya, unfortunately I have take off my y pipe to get my transmission out. I have PacesetterLT's and pacesetter ypipe.
Old Jan 12, 2005 | 11:31 AM
slow96z's Avatar
If you're in S.E. Houston I have a spare yolk (sp?) you can use to plug it.
Old Jan 12, 2005 | 03:22 PM
BAD2000TA's Avatar
A spare yoke would stop the leak, but might not clear the y-pipe. I'm not taking the exhaust for this. I just want to know if anyone sells the plug locally. Is the tailshaft the same as a TH350 (size-wise)?
