paint gun question?
Old Jan 21, 2005 | 12:42 PM
bbz's Avatar
bbz
Question paint gun question?
I'm using a typical spray (that is not HVLP)gun to paint some iron fences and need help adjusting the spray.
I believe the top **** is for air pressure and the lower **** is for volume.
When I first bought it it painted fine. I've changed colors and cleaned it and know can't get it to spray the way it did at first.
I want to have it spray a nice wet looking coat.
Currently it is spraying too lightly no matter how I adjust the *****. Is this signs of a dirty gun?
thanks
Old Jan 21, 2005 | 12:49 PM
WS6snake-eater's Avatar
It could be an air pressure problem...Is you air source regulated? Do you have a gauge to show your PSI going to the gun?
Old Jan 21, 2005 | 02:29 PM
FIREHAWK #07's Avatar
I had to paint a fence one time...... turned out the paint was too thick, I just added some water..... worked for me
stupid fence
Old Jan 21, 2005 | 03:41 PM
bbz's Avatar
bbz
I cleaned the gun again and added a pressure regulator at the gun.
The cleaning helped, but the regulator wasn't able to adjust the pressure below 80 #'s ???
The cleaning may have helped but a little but it still appears to be "sandy" . I wonder if the regulater is the correct one. I bought this one at home depot, a huskey brand, that is supposed to adjust the air pressure from 0-max in a 1/4 turn. I can't adjust the pressure below 80psi. ???
The paint I'm using is oil based Rustoleum primer and paints. I havn't had a problem before.
Old Jan 21, 2005 | 08:03 PM
Black Z's Avatar
stupid fence
yeap
Old Jan 21, 2005 | 08:04 PM
Black Z's Avatar
Add some thinner till it sprays like u like it
Old Jan 22, 2005 | 01:47 AM
A_W_O_L's Avatar
what he said...paint thinner....i personally dont think that i could talk myself into putting WATER through a paint gun....
then again i dont paint cars for a living.
