Small Chirping noise
before, we are not sure if the chirping was there or if its a new sound that just started. Everythign is in there pretty tight, is there a way to tighten the belt anymore than it already is? since it has that tention pully, can it be adjusted to be a little tighter to see if maybe the chirping/sound is coming from the belt and not something else?Its a 99 TA....
You might get luck and try lubricating the belt tensioner pulleys. It might be coming from there. Just don't spray on the belt side!
Good Luck!
Brian
