accessory power
Old Feb 7, 2005 | 10:41 PM
BigSteele's Avatar
Default accessory power
I posted this in the stero/elec. section, just wanted to post it here too to see if I can get some more info. I usually just look at the texas forum and rarely the others, so this is for those like me.
Originally Posted by BigSteele
I need to run a couple things using the ACC. power as the component's main power source (shift light, QTP cutout, radar power) I know the pink ASR wire is ACC on but i dont want to run too many things off that. I was thinking of running a 12v relay with that ASR wire to turn it on, and then have some sort of "junction block" with a couple taps to hook things up to (like on some amp fuse blocks).
Im worried about drawing too much power from one wire, I think it would be better to hook up a relay with some thicker gauge and have a couple 12v ACC outputs.
What do you guys think?, can I get the 12v from the inside fusebox, how should I hook up the "junction block", would it be okay to do this, one commom 12v wire?
Or, how do you guys wire up the ACC wire when you have several components?
Thanks
